Posted by glennster on December 29, 2009 at 13:53:36 from (76.217.101.141):
In Reply to: M Rebuild posted by ChrisMO on December 29, 2009 at 07:24:14:
chris, if you"re gonna go thru the motor, do it right the first time, then your done with it and you have a good reliable tractor. you can get the overhaul kit about anywhere, last one i bought for my super m came from yt here. some advice i"ll pass along. take the crankshaft to a machine shop, have them check it and have THEM get the main and rod bearings. if you dont have a sleeve puller, have the machine shop pull the sleeves and install the new ones (in case the deck needs to be surfaced.) my sleeves stuck out too high. the i&t manual isnt a bad manual for the price. pull the lower cover off the oil pump, check it for wear, and be sure the relief valve moves freely. be sure to mark each lifter when you take them out of the bore so they go back in the same hole. check the clutch when you pull the motor out, now would be the time to replace it if needed also, check the ring gear on the flywheel to see if its chewed up. they can be flipped over if not too bad, new aftermarket ones are reasonable too.
Today's Featured Article - New Life for an Old Allis - by Tyler Woods. My friend Jon, has an old '39 Allis Chalmers B. He thought it a marginal tractor that had long since served its time. She smoked terribly and never had much power but he couldn't afford another so he was limping along with what he had. Jon's Allis has a small front loader and though it doesn't carry much, it serves his needs. It was the hard starting and low power that made him think it was time to replace the old girl. Jon called me to help him discover why his tractor wouldn't start
... [Read Article]
Latest Ad:
[More Ads]
