Posted by Red Mist on December 31, 2009 at 14:22:36 from (72.171.0.138):
In Reply to: Keyed ignition wiring posted by ScottyHOMEy on December 31, 2009 at 13:32:23:
Jack:
After re-reading your post, it appears, based on your description of your old switch, you have keyed igniton AND keyed start. Basically, here is how that works:
(1) You are going to have a hot wire from the battery coming in onto the switch. That's one post.
(2) When you turn the key to the "on" position (check with continuity tester) one of the other posts is going to get hot. The wire from that post goes to your coil. That's the second post.
(3) The third post will get hot only when you twist the key to the momentary/start positon. (Again, check with continuity tester.) The wire from that post goes to your solenoid. That's your third post.
You can easily figure out which post is which with a simple continuity tester.
Hope that answers your question.
mike
This post was edited by Red Mist at 14:29:05 12/31/09.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
