Super C governor killing engine
Posted by SteveinFL on January 01, 2010 at 17:59:50 from (4.235.81.141):
After cutting down some trees I was using the Super C to drag a log out of the driveway this week when while under load the engine stalled and started to rev up and down hunting for the proper speed. I could start it but it would constantly rev up and down and when I put it in gear it would die.
After initially fearing the worst I am thinking that something gave out in the governor but I am not sure. I checked all the linkage and everything is fine. I have spent some time making adjustments to the bumper spring screw on the bottom of the governor following instructions in the I&T manual. Now the engine will start and run great for about 5 seconds and then the governor will adjust on its own and stall the motor. From the seat I can lean over the side of the tractor and watch it happen. That is the best I have been able to do so far.
Before I really start to get in deep I wanted to see if you guys have any ideas on what else I can check from here. Thanks for the help.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
