Posted by Michigan IH on January 03, 2010 at 13:54:05 from (198.208.159.20):
My gas 340 utility runs fine when first started, but after 20 or 30 minutes (especially if idling) it starts to run like the choke is out. It stumbles and sputters when you give it gas, it does the same when it encounters a load. Sometimes it will back fire through the exhaust. It has 1900 hours on the meter. I installed a new crank at 1400 hours but have not had the head off. This condition occurs in cold or warm weather. In addition to the poor running, the carb is also wet on the outside all the time and moisture comes down the block from the manifold runners. I tried a heat houser last winter with no impact. Any ideas??
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
