Posted by deano4863 on January 03, 2010 at 18:05:20 from (76.30.75.21):
My SH Radiator has developed a leak in the tube that the steering shaft goes through. Is that rapairable. Obviously the alignment is not good. It is rubbing on the lower right side as you face the radiator from the seat. I tried to shift it to the right a little bit but it won't move enough to clear. I tried to adjust the pitch with the support rod. That helps a little. It has 1/4" pads and both sides are sitting on the bolster. This tractor also has the IH WFE which means I have to drop the front end,:(, to remove the radiator. Has anybody figured out a way to reconfigure the mounting system of the radiator such that I don't have to drop the front end?
Today's Featured Article - Fasteners: The Nuts and Bolts of Nuts and Bolts - by Curtis Von Fange. The nuts and bolts of nuts and bolts is an interesting and essential piece of knowledge that applies to our older tractors. An improperly torqued capscrew on an engine head or a shear bolt that is too hard on the driving shaft of a bushog can create havoc and make an expensive and uncalled for repair. Let’s examine the purpose and design of these fasteners in order to ensure their proper use. Fasteners are probably one of the aspects of mechanics that is given the least amount of thought.
... [Read Article]
Latest Ad:
[More Ads]
