I did mine exactly as mkirsch describes - unscrewed the front plug then rolled the worm/bearing/shaft assembly forward.
If the input shaft seal is worn out don't worry about it. Simply pack the gear box full with good quality grease before you put the cover back on.
Tip: Use new roll pins at both ends of the coupling (should be a small one nested inside a larger one).
When I took mine apart I found an inner pin was missing and the outer one cracked. It was simple good luck the cracked pin hadn't sheared resulting in a loss of steering.
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
