Re: Warming up the MCV on 706
Posted by mkirsch on January 07, 2010 at 12:49:21 from (64.80.108.55):
In Reply to: Warming up the MCV on 706 posted by Rtkman706 on January 05, 2010 at 19:30:31:
I don't believe it because I understand how the system works, and what you describe equates to "cartoon physics."
Oil heats up faster when it's pumped under pressure. If you just hook a hose between the two ports, and tie the lever back, very little pressure is developed and very little heat is generated. The oil just blurps out the top hole and runs back in the bottom hole, or vice versa.
In order for your scheme to work, you'd need a restrictor in the hose. That's a fitting with a tiny hole through it instead of a full pipe. They make them in straight hose couplings, and elbows.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
