Re: 656 3pt lift problem
Posted by Ted in NE on January 08, 2010 at 07:05:24 from (74.85.105.44):
In Reply to: Re: 656 3pt lift problem posted by Steven Kautz on January 08, 2010 at 05:33:18:
Steven,
The relief for the 3pt. is under the square plate under the seat as Tractorman said. Remove the seat & cover. The hitch relief is in the right front corner. Try to lift a bale & see if oil comes out the top of the relief. If it does you can screw the slotted part of the valve in to raise the pressure. Try a 1/4 turn at a time. Have done this many times to raise a heavy planter with no problems. Just go enough to raise the bale. If the valve does not leak when trying to lift your pump is probably weak.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
