Posted by soybeanjoe on January 08, 2010 at 15:08:23 from (66.213.171.108):
In Reply to: Duals on a 1066 posted by blkeele on January 08, 2010 at 13:40:10:
You can put axle mount duals on either axle length. problem with the short axles the tires will almost touch unless you are settup for 30" rows (60" centers on inside rear wheels).
If you are on wide rows "36" or wider) you can either go with the snap-on duals as the previous poster mentioned or by a set of extensions to put on the axle mount hubs. I had a 656 with the shorter axles. I used the extensions & got along ok with them.
Only problem was they were a bit of a PITA to tighten or loosen. I always took them off when I took the duals off & left the dual hubs on. I had to use a flex end on the socket extension which didn't make for good leverage. if you would leave them bolted to the hubs that wouldn't be a problem but I didn't like them sticking out that far. I would take off the dual, then remove the extension & leave the hub on the axle.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
