Posted by CNKS on January 08, 2010 at 18:26:01 from (216.144.104.128):
In Reply to: Clutch on a 606 posted by gqjoe on January 08, 2010 at 18:06:47:
I was having pedal clearance problems on my 460 (same clutch I think). I tried the washer thing -- it did not help. The problem is worn linkage. Too much play in the linkage before the release bearing contacts the fingers, meaning there is too much play in the pedal. In order to get it to work properly, the fingers are against the release bearing all the time at full throttle, not at idle, meaning centrifugal force forces the fingers out -- will probably eventually ruin the bearing. As to installation, you need to get I&T manual IH 25. The TA has to be adjusted at the same time as the clutch, I&T is better in that regard than the IH clutch manual. When you install the clutch and push the tractor back together, do not attach the pressure plate and disk to the flywheel until the tractor is back together. Unless you have perfect alignment, you will bend the clutch disk, I learned that the hard way. To answer your question, the washers were there in an attempt to get the clutch to fully disengage to prevent gear clash when shifting, if I remember right. Best to leave them out. Also, you may need to get the flywheel ground. If the previous owner did not have the machinest take the same amount off the step on the flywheel as he took off the surface it messes things up. I forget the correct step height. You will find it at www.hicapacity.com
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
