What is your technique for removal of the guide lens from the housing/reflector? I experimented with a light with a bad housing body (had rust holes through the back) and found that I could pry the crimp off the lens by first grinding (thinning) the outer edge of the metal crimp.
I also tried using a reflector w/bulb socket from an IH (older) bulb type light. It would fit the pancake housing with a little grinding of the edge, but had a bent lip around the circumference which prevented it from seating to a proper depth for both the gasket and rim - together. I could put it together without a rubber gasket, but that would not be good for the long haul...... Thanks.
mike
This post was edited by Red Mist at 17:48:13 01/09/10 2 times.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
