Posted by brmtdg on January 12, 2010 at 09:35:30 from (71.57.218.99):
Currently starting work on a recently purchased 300U(no TA) that has a shifting problem.
Reverse and First shift quite smoothly and Fourth and Fifth are OK. But Second is stiff and Third is a real bear or almost impossible.
Searching the forum brings up some issues with shifter wear. But most of these are problems of engaging two gears at once or can shifter wear cause my problem. What problems does a worn shifter cause usually? There is some wear on it but it does not appear excessive for a 50+ year old tractor.
Other idea is the shifter rail/linkage is sticking from either wear or excessive crud. Would adding some kerosene or something help clean out the crud. If so what/how would you all recomend I go about it. Would like to try all the obvious and simple fixes before removing the transmission case top.
Overall the tractor is solid and complete with most everything working with this exception and some minor issues(leaks,electrical,tach).The sheet metal straight just badly faded,tires like new.
As always any opinion,comments and advise is greatly welcomed. Thanks BRTMDG
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
