Posted by pete 23 on January 12, 2010 at 09:46:18 from (173.87.15.32):
In Reply to: More Magneto ?? posted by Kevin in MI on January 12, 2010 at 06:51:29:
You must keep in mind that a magneto does indeed have a distributor, it needs this to distribute the spark to the correct cyl at the correct time. The other type commenly referred to as a distriutor is in fact a battery ign unit and also has a distributor. The battery ign unit has a variable speed automatic advance whereas a magneto has an impulse induced spark lag for starting and then it is full advance at all running speeds. This is less deseriable for smooth effecient operation at speeds below full throttle. Also, the battery ign units come in many differet advances,from 40 degrees to zero degrees depending on engine designed for. Don't know your tractor model but a 30 or 40 degree automatic advance working properly would most likely be what you need.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
