Sounds like the idle fuel mix goes lean on long runs. When it happens again try gradually pulling the choke while throttling down. If you find a partial choke setting where it will slow idle OK a lean mixture is the problem.
Possible causes:
1 - Carb idle mix set too lean. Turn the mixture screw IN 1/4 turn at a time to make it richer.
2 - Loose gasket opening up when the engine gets hot allowing a vacuum leak. Check the carb-to-manifold and manifold-to-head gaskets for leaks and the studs & nuts tightness.
2 - Crud floating around in the carb getting sucked into and plugging the idle fuel circuit on long runs. Need to disassemble and thoroughly clean the carb and fuel inlet screen!
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
