jasonjaberdeen said: (quoted from post at 00:31:03 01/13/10) Help please...
I just changed the hydraulic filter on my 706 and I cant get the loader to work properly.
the power steering, brakes, and TA work ok but not the loader...It does move but it acts like I have air in the system... Any advice?
Did the loader work Okay before you changed the filter?
What are the symptoms you are having that cause you to believe there is air trapped in the loader system? Air in the system should not keep it from lifting but will cause the cylinders to act like they are mounted on springs.
The 706 uses a separate pump for the hitch and auxiliary valves. It is likely that you have a problem in the rear system that still allows the front system to function normally. If you give us a better description of your problems we will be able to suggest some things to look at to discover the problem.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
