Posted by riverbend on January 21, 2010 at 06:59:41 from (208.160.33.198):
In Reply to: B engine block cracks posted by gurneejoe on January 20, 2010 at 20:02:55:
That's bad. Are there cracks between all the cylinders ?
I had a block welded that had cracks similar to the middle picture, that went between cylinders 2 and 3, and between 3 and 4. I looked for a couple years and could not come up with a good used block, and really wanted to use the tractor.
The spray welding cost me $12 per inch a few years ago. The surface of the block was machined and the sleeve recesses rebored. There was a big crack behind the carb too. The welding cost $288 and the machine work was $45 (IIRC).
The repair has held up so far and the cost was about the same as a used block. Welding worked for me. I'm not sure if brazing would be strong enough.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
