Posted by jimb2 on January 21, 2010 at 19:25:39 from (99.240.236.11):
In Reply to: IH 484 brake problem posted by DelmarInVA on January 20, 2010 at 20:29:03:
Hi, check for hydraulic fluid leaks from under the dash where the brake master cylinders are or for leaks along the top of the transmission housing. The brake lines run on top of transmissision housing to under the seat and then into rear end by axle housing. Check under the sheet metal on top of transmission housing. The sheet metal cover that is between the seat and the dash. If that is all good the bleeding the brakes will usually fix it. Do not pump the brakes without engine running.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
