If it has numbers on the bottom, or top/sides, the number can be referenced at a NAPA, or possibly google for it (put in voltage regulator xxx-xx-xxx) filling in the number as printed on the reg. If no numbers are on it, the pull in voltage of the cutout relay would do it.
With the following items a 6v battery, a variable voltage supply from 0-20 v, the Voltage reg in question, a volt meter (if the power supply does not have one built in), and some jumper wires.
Connect the battery + to the Power supply + Connect the power supply - (with the volts at zero) to the arm terminal of the reg. connect the Bat term of the reg to the - battery post. Connect the volt meter across the Arm to Bat terms of the VR with the black lead on the arm terminal.
Begin turning up the voltage watching the meter. as the voltage gets between 7 and 8 volts, a click should be heard as the cutout closes, and the meter across the relay should go to zero. This is a 6 volt reg. If it gets to 13 volts or more before clicking, it is 12v. If it does not close, or is permanently closed already, it is toast. JimN
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
