Re: Voltage Regulator Rating
Posted by Jim Becker on January 22, 2010 at 07:16:07 from (173.57.141.22):
In Reply to: Voltage Regulator Rating posted by Doug Kieta on January 21, 2010 at 18:16:15:
440roadrunner said: I doubt that he's got a variable supply or he probably would not be asking, but I'm not convinced that your method will work?????
A cutout has a series and a shunt winding. The shunt winding is the "voltage" winding, seems to me you'd have to connect the power supply to the A (G) and ground of the regulator, but it would be MORE accurate to watch for the voltage regulator relay to click in, no?
The regulator would have to be grounded for this test to work. I have never tried testing this way, but suspect that a 6/12-volt battery maintainer is all the variable power supply required. With the maintainer set at 6, a 6-volt cut-out should kick in and a 12-volt not.
I also think the test can probably be done without a battery, just connect a voltmeter between the regulator ground and BAT terminal.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
