Farmall B antifreeze in oilpan
Posted by Stephen McCoy on January 26, 2010 at 12:06:10 from (207.165.188.44):
I have a 1945 Farmall B that my students and I are in the process of restoring. When we drained the oil the first thing to come out was nice bright green antifreeze, followed by the oil. I have pressurized the radiator and looked for leaks around the sleeves (suspected lower o-ring may have been bad on sleeve) and have not seen any leaks around them nor are there any coming down the oil galleys from the head (suspected headgasket).
What I have seen in a very faint hairline crack in the block on the inside of the crankcase just behind the carburetor. I saw a couple drops of antifreeze there when I first had the oil pan off. I wiped everything dry before we began searching for leaks. After sitting for the weekend I noticed a few drops of antifreeze under the tractor right below where I saw the drops in the crankcase. Sure enough they we back in exactly the same spot I first saw them! It looks like there is some weeping coming through what looks like a crack on what would be the bottom of the water jacket into the crankcase.
Any ideas of how I can stop this leak short of replacing the block? Here's the picture I was able to take of the leak. What look like little bumps in the casting are actually the drops of antifreeze/water. The apparent crack starts from the far left drop and goes horizontally across to the right. Thanks.
third party image
This post was edited by Stephen McCoy at 12:07:40 01/26/10.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
