Brian Peppler said: (quoted from post at 14:32:07 01/28/10) I was looking at the end plate and I think it might
be strong enough for me to remove it and drill and
tap a 3/8 national pipe thread into it and then run
some hydro hoses out and run that to a couple open
center valves.
Yeah, but you can't just drill holes in the end plate.
It's an open center system, which means there can only be one path for the hydraulic fluid through the entire system.
If you drill holes, you create a second path for the fluid to flow. The fluid will always take the path of least resistance, and NONE of your hydraulics will work anymore:
You pull the lever on your spool valve, and the fluid will flow through the 3pt valve. You pull the lever on the 3pt valve, and the fluid will flow through the spool valves.
To work, fluid has to flow out of the pump, through the spool valves, into the 3pt valve, and back into the reservoir.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
