Got it done today. Drained the coolant, approx 3 gallons collected, some got away. Removed the inlet casting and used garden sprayer to flush it out through top and bottom openings. Lots of brown/orange water and some chunks of mud and scale. Flushed both ways for about 30 minutes until water ran clear. Check tempertaure probe while I had it out with a pot of boiling water. Checked out OK (it should, it's new, but probably made in China so I needed to verify). Buttoned it all back up and filled with drained 50/50 mix (it was clean) and added a little more to make up for the displaced sludge and escaped coolant. Cranked it up, waited a few minutes to get warmed up and then ran her up to 3/4 throttle. After 15 minutes no movement on temp gauge. So, to accelerate things, I covered the front of the radiator with a trash bag. 10 minutes later the temperature started to rise a bit (still in cool, but movement is good, means it is working). 10 minutes later it was almost up to "Run" level on the temp gauge so I removed the trash bag. 5 minutes later it was back to below cool. That is one efficient radiator! Ambient temperature was 45 deg. I opted not to run a flush kit through it at this time.
So now I know it is working correctly. It is good to be validated with hard evidence. I suspected it was working fine, but just wanted to be sure. Thanks for all the advice and suggestions.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
