the h is a 1946. it probably did not come from the factory with fenders, they were an option. the tractor was originally 6v positive ground. regarding the stuck motor, there are quite a few different ways to unstick em. personally, i would first drain the engine oil and look for water or antifreeze. pull the spark plugs and peek in to see what the cylinders look like. if you can borrow a bore scope, that would be great. next, pick up a spray can of pb blaster penetrating oil. pull the valve cover, spray up the rocker shaft , and valves, spray the rest in each spark plug hole, put a fresh drain pan under the tractor and let it set over nite. look for penetrating oil the next day in the pan. at this point, fill the cylinders with automatic trans fluid and let the tractor set. check the tractor every day and look for atf leaking out of the drain hole. try rocking the tractor in 4 th gear every day to see if it breaks loose. also see if the valves are loose, and lube the whole works up with trans fluid. he may be lucky and the motor will free up.
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
