Answers: The hose from the non pressurized end of the cylinder acts as an extended reservoir. To do this it needs to be connected to the reservoir. there is no provision for this use, so a 1/2" npt "T" and a close nipple, are used in the bottom of the pump housing this allows draining and access to the reservoir for the hose from the non pressure end. Putting the hose in the filler pipe will not allow it to suck and push the extra fluid. Doing this keeps the cylinder lubricated at the packing, keeps water and dirt out, and allows a larger res capacity. The control rod with a loop on the end has 4 positions (three being used) hold is a mid travel position with the little welded on tab hooked on the support casting. This is basically neutral, and holds the cylinder/s at their current position. Pulled out all the way, it lifts. Pushed in all the way it lowers. Pushed in 1/2 way from hold is delay lower. (operates on the left rear outlet only) You can ignore this aspect unless fitted with a old IH cultivator, or other sequential lift implement. Both left and right regular outlets are "T"ed together inside, not separate. IH Hytran or JD hydraulic Transmission fluid are great. I would not use the ND oil as it may have been as good as was available then but Hytran has much better properties. (it will mix with residual oil in the unit, no flush needed after draining. JimN
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
