Re: 1066 tach RR
Posted by Michael Sheik on February 06, 2010 at 10:02:37 from (65.255.85.187):
In Reply to: Re: 1066 tach RR posted by Allan In NE on February 06, 2010 at 07:03:03:
I used a 5/16 flat screw driver(a new one with good square corners) and only forced one corner of the blade under the crimp holding the screwdriver at about a 30 degree angle to the tach face. I started at the little notch on crimp on back side and gave it a twist to open up the crimp just a little bit and did that about every 1/4 inch all the way around and went around it 3 times. I didn't stand the crimp up but left it about 1/4 over as I figured it would be hard to crimp back if I completely opened it up. I used two really small(about 1/8 inch) flat screw drivers and worked the ring over the rolled lip on the tach case. I was lucky that I didn't even nick that little tiny paper gasket. Hardest thing going back was working that ring back over the lip on the case. To start the crimp folding back down I used a slip lock pliers and wrapped 4 or 5 wraps electrical tape around bottom jaw to keep it from scratching chrome ring face. Held tach upside down, placed taped jaw on front face of chrome ring just past the edge and other jaw on crimp back side and while squeezing pulled upward on plier handles. Went around it twice before I had the crimp almost back tight. The third time around was with a vise grip to squeeze the crimp tight. I was happy that you can't even see tool marks on that chrome ring unless you look really hard.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
