Dick Binfield said: (quoted from post at 21:40:52 02/08/10) Will 9.50 x 15 tri ribs on 6 bolt 8 in rims fit on an M with factory wide front-- tie rods in the rear? I found a good buy on these tires and rims but need information as to whether they will center up on the spindle/hub.
An M normally would not have six bolt hubs on it but there are some that fit the spindle. If you have six bolt hubs most likely the wheels will bolt unto the hub.
As far as if the wheels and tires would fit you would also need to have the right offset in the rim so that they do not rub. Measure how much clearance you currently have between the tire and spindle and then measure the offset of the rim. Compare that measurement with the wider wheels/tires and see if there is enough room to clear.
Keep in mind that the wider the tire the more the center of the tire contact will move away from the pivot point of the spindle. The farther apart those two contact points are the harder it will steer and the more stress that is placed on the spindle and bearings.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
