Posted by Bobcat on February 11, 2010 at 13:51:46 from (69.66.139.140):
In Reply to: F20 engine tools posted by IH nut on February 10, 2010 at 16:06:56:
I pulled the flywheel off a F-30 by installing grade 5 bolts into the 3 holes already drilled in the flywheel. Make the head of the bolts stick out so a really large 3 jaw puller will hook them on the outside. Make a plate to cover the pilot bearing in the crank. As long as everything pulls straight it will pull right off. As far as moving the crankshaft out of the block a block of wood and a good old sledge hammer works just fine. Now to get the bearings off the crank invest in a 50ton press.
Putting things back together requires heat differential on the flywheel and bearings. Nothing real "IH" special needed!
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
