Posted by Owen Aaland on February 11, 2010 at 18:43:10 from (65.165.246.14):
In Reply to: 966 Hy-Tran leak posted by AJinPa on February 11, 2010 at 18:04:18:
It sounds like you differential lock is working like most of them, if you try to use it, it leaks. Make sure you get the diff lock control all the way back up to completely stop the oil flow to the diff lock assembly.
There is a line under the cover that gets oil to the diff lock clutch. There is a seal that is supposed to keep the oil from leaking but since the clutch is always revolving around around the end of the tube, the seal gets worn out fairly quickly. Replacing the seal will not necessarily stop the leak because the end of tubing also gets worn.
If the leak is present even if the diff lock is not used, then the cause most likely is the seal between the bull pinion and the diff lock shaft.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
