When you decide to install the mag you need to see where the rotor is pointing on your distributor before you remove it, THEN Don't move the engine. Once you have the distributor removed turn the rotor on the mag to the same position as it was on the distributor and install it. Make sure you install the plug wires on the cap in the correct firing order: 2-1 4-3 as the rotor rotates CW. Hal PS: You need to install a switch for grounding out the mag to stop the engine. Disconnect the wire from your ignition switch as you don't need battery voltage for the mag.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
