Posted by pete 23 on February 14, 2010 at 10:29:25 from (173.87.0.197):
In Reply to: m head swap posted by lee. s on February 13, 2010 at 20:42:41:
A 400 gasoline head will give you a considerably higher compression ratio than you have with a kerosene head. Should gain a few ponies. I think I would try both carburetors to see which one gives you the best performance. As the 400 used a 25 degree spark advance at full throttle, you may need to adjust your M ignition. Most M's used 40 degree with battery ign and 35 with magneto. Bore size will also affect comp ratio. I would only resurface head if it is needed for flat true surface
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
