Stop how you are doing it, because it will break the bull pinion carrier. In order to remove the carrier, you need to remove the bull gear from the axle, otherwise the carrier will catch on the bull gear and break off part of the back side that holds the inner bearing in the carrier. If you really want to continue, the easiest way is to jack up the axle housing, remove the PTO, and rear wheel. Remove the bolt inside the trans that holds the bull gear to the axle, remove the axle cap and pull the axle out. This will also give you a chance to inspect the axle bearings, and replace the axle felt and oil seal. After the axle is out, and the bull gear moved out of the way, then remove the brake and bull carrier from the tractor.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
