Posted by Owen Aaland on February 18, 2010 at 07:45:26 from (198.70.47.146):
In Reply to: Farmall 966 posted by John Benson on February 17, 2010 at 17:45:20:
To remove the valve you need to remove the rubber cap. There is a small snap ring that holds the disk on the valve stem. The valve is removed from the underside of the cab.
If you are expecting the differential lock to completely lock both rear wheels together it's not going to happen. A good working diff lock on a 66 series at best will cause the front tire side walls to flex a little if you are turning on dry ground but the tractor will still turn. Barring excessive front end weights, an 86 series diff lock will cause the front tires to slide under the same conditions.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
