Posted by Coax on February 19, 2010 at 14:46:35 from (24.113.118.113):
In Reply to: J-4 Magneto reloaded posted by usetabesteve on February 18, 2010 at 22:09:29:
Ole Shovel said: (quoted from post at 00:16:08 02/19/10) The wire to the points and the ground tab on coil have to disconnected to check it. Points wire to the center secondary output button should read no more than 12,000 ohms max secondary resistance. More than that or no reading at all it"s bad. Then from the points to the ground tab on side of the coil no more than .4 ohms max primary resistance. Again more or nothing it"s bad. You may get decent readings there and the coil could still be bad because of windings or insulation breaking down inside that only be checked on a coil tester that does a load heat firing test. Same readings also work for the IH H4 magneto.
Its as you say, I took the coil completely out and I get .4 ohms wire to ground strap... But no reading or O/L from wire to HV button...Damn. So even tho its a HV winding at the button I should still be getting some reading Right??? Crap looks like a Rebuild kit for me. Thanks for the Help.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
