there are up and down and forward and back adjustments on the radiator. adding shims under the radiator raise it, and the strut rod will give fore-and back tilt. the limiting factor is the hole in the radiator where the steering shaft goes thru. adjust it high enough for clearance without any rubbing. use clay or even play dough on the top of the bolster to check clearance from the bolts to the sheet metal. also, be sure and check the clearance between the radiator shroud and the engine cooling fan.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
