Posted by jimb2 on February 21, 2010 at 09:24:53 from (99.240.236.11):
In Reply to: 674 won't start posted by colin buchanan on February 21, 2010 at 08:56:04:
Hi Colin, make sure you have bled all the air out at the bleeder screws on top of the fuel filter(s). With the STOP/START/RUN lever on the START position and throttle 1/2 open and if you have an air compressor gun and clean cloth stick the air gun in the fuel tank filler and seal with a clean cloth and slightly pressurize the fuel tank, now start cranking the engine with the starter. WARNING DO NOT crank the starter for more than 60 seconds, then let it cool for a couple minutes, then crank engine again. IF the above dosen't work then you will have to loosen the nut on one of the lines from the injection pump to the injectors at the rear of the injection pump and then crank engine again.
BECAREFUL when loosening nut on injection line as the Diesel fuel is under 3000 plus psi and can cause serious injury.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
