Posted by The tractor vet on February 21, 2010 at 16:33:03 from (75.19.124.251):
In Reply to: 706 brakes posted by ratnickwi on February 21, 2010 at 16:17:03:
Well here i am not real sure what your telling me , but even if the axle housing has been off and one side drilled to take oil from the main housing the level would not be that high to have oil Gushing out . So either for some really odd reason it is that over full and here i would pull the check plug to see or it is slinging oil out past the bull pinion seal that bad or the brake piston is leaking that bad . Now if the bull pinion seal is out check for a bad bearing or two on it . Now as for the brakes yea i have seen some really nasty ones on some of the 706's that i have bought . And when redoing them do it all and be done with it , make sure that the adjusters are free and set when you put it back together Install NEW return spring and what ever flavor brake lining you so chose . And install new seals and O/Rings in the brake piston and with a medium grit emery cloth clean all the surfaces where they ride on . .
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
