Yes, I put the resistor inline to the #1 terminal from the ignition switch. I only use the resistor by itself. Lots of guys use the light or diode & get by. Your alternator problems could be caused by the brushes being worn or maybe the diode trio being bad. Our 1460 alternator had 2 of the 3 feed strips melted when we were getting it ready for the field last fall---no obvious reasons for it to happen. You can take the alternator apart & see what is going on inside. Test the diode trio using an analog meter on Rx1 scale. Should read ~ 30 to 40 ohms in one direction & infinity with the leads reversed checked at all 3 terminals to the single lead going to the regulator. This is done with the diode trio removed. If brushes/ brush holder is bad, it will be evident. Hope this helps--these alternators are pretty reliable as a general rule--you just have a small problem somewhere.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
