Posted by sflem849 on February 23, 2010 at 14:00:44 from (69.197.84.192):
In Reply to: Brake bands on H posted by Erik Dekeyser on February 23, 2010 at 09:26:57:
charlie M said: (quoted from post at 13:10:25 02/23/10) You don't have to take the whole tractor apart to fix your oil problem. There is an oil seal behind the brake drum that is easy to fix. If I remember correctly there is a bolt on the end of the drum that comes out and the drum slides off the shaft. The oil seal is right there. If there is oil leaking from the bull gear holder (not sure exactly what that part is called) that requires removing the top and doing a lot of stuff. Most likely though all you need to change in the oil seal.
I believe it is called the bull pinion carrier. You are correct about the other stuff.
I would wager if the oring is leaking on the BPC (Bull Pinion Carrier) you could back it out until you feel it hit the bull gear and have enough room to slip an oring on. With all that said, the oil would be leaking down the rearend prob not into the brake area.
The Tractor Vet's procedure is dead nuts on and not nearly as hard as it sounds. The bull gear is heavy and that might cause some problems in getting it lined back up. Having done it once with everything apart I bet I could redo it in a weekend no problem.
My local independant IH repair man says you can change out that big double seal on the BPC w/o taking the BPC out. I tried it and then...well...I don't want to talk about how my BPC broke. Looking back I would guess it could be done. The outer half pried out really easy. The outer cage is really tough, but you could do it. I doubt the guy is making it up. He moves A LOT of tractors through the shop.
I found three extra problems with everything apart so it was all well worth it. After I put new seals in everything it was about $300 plus $250 for some bad bearings and gears and poppet springs. Most seals were from IH, but I should have got them from the bearing shop bc most were half the price of IH.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
