The outer shaft goes in to the pressure plate and that is always urning and the inner shaft goes onto the clutch disc and that stops turning when you press down on the clutch pedal . The outer shaft is hollow and there is a gear on the back side of it and it turns a gear that is below it and the shaft that goes into that gear runs thru the bottom contour shaft in the transmission and it goes on back to the PTO unit , the unit has a clutch pack or planetary gears and a sorta of a brake band that will engage the outer PTO shaft and give you non interrupted power no matter if the tractor is moving or not
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
