Posted by pete 23 on March 01, 2010 at 17:53:33 from (173.87.0.197):
In Reply to: 1206 pto problem posted by joe 1971 on March 01, 2010 at 16:12:39:
Did you check or replace the teflon seal rings and o-ring on clutch drum and shaft. I always use air pressure when assembling pto before I put the pump assembly on. Air should activate the clutch piston when applied into port that pump supplies oil too,with you pulling on the valve by hand. If not, no need to assemble any farther until you find where leak is. It will not seal 100% but should move the piston with air pressure.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
