I'll buy that. I don't believe that risk of fire is greater either way. I have never seen vapor flash in real life, only on saftey videos for both work and the FD.
Either way you would fill you have to feed liquid hence the advantage of a pump. I guess I would do it either way and feel comfortable, but I certainly wouldn't turn down a cheap pump!
To the OP. It just wouldn't be practical for you to get a tank at home just to fill your tractor, but as said you would probably only need to fill it once a year. AND If you run out you can always use a 20# tank to keep it moving.
Wasn't that you that posted about $200 tires? Where did you get those?
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
