1-fuel supply, check to make sure you have good flow to carb.
2- spark at plugs / check plugs are they wet?
3- make sure timing is right
4- has to run,if all above is correct.
I have had a similar situation as yours, and yes it turned out to be a timing issue, turned out to be a mess of problems, previous owner had governor gear mark not mated with idler gear, I confirmed this by finding top dead center, removed dist cap, and rotor was pointing at no nipple. it would not fire. just for thought, crazy things can happen, Jim
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
