Mike, keep in mind that when the engine is idling there should still a small bit of tension on the spring because the flyweights are still trying to sling out. If the stop bolt won't contact the case, check your rod linkage over the head. It should push down far enough on the governor lever so the spring isn't pushed.
Yes, there is an idle stop screw on the carburetor. It is the one pointing perpendicular to the butterfly shaft and slightly above it.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
