Re: Re: More H Problems
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Bill {Antique Acres] on May 03, 2000 at 11:01:29 from (63.162.254.66):
In Reply to: Re: More H Problems posted by The Red on May 03, 2000 at 09:34:53:
I had the same problem with my 49' H. It would run just fine then die after a couple minutes. Turned out the some kids put some shredded carboard in the tank. I doubt that's your problem, but you could have something in the tank causing the same thing. It would let enough gas go through and fill up the carb and gas line, but would not let enough gas go through quick enough to keep it running after the carb and line were drained. If you let it sit 20 minutes it would start up and do the same thing. I would check your tank and make sure nothing is blocking the opening. I would also take your bowl aasembly out of the tank. Sometimes that old pot metal they use on the them gets weak and breaks of and plug the hole up in the aseembly and you won't know until you take it off. Let us know what you find out. Bill {Antique Acres}
Post A Followup
: Re: Re: Re: More H Problems
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
