Re: 966 doesn't like low range...
Posted by The tractor vet on March 04, 2010 at 19:41:56 from (75.19.124.251):
In Reply to: 966 doesn't like low range... posted by GEJD60 on March 04, 2010 at 18:16:39:
I do not think it is a adjustment issue , more like worn or loose linkage or you have a broken roller in the range cover or on the shifting fork . adjustment is the last thing i look at . So pull the right cowl sheet metal and work your way donw and see what all is worn . everything must be snug with no play . At times the headed pins get excessive ware and they get sloppy and a little ware here and a little wear there adds up and ya get a no go . So ya start at the shifter and work your way down to the range cover and then if you have to remove it , BUT you need to pull the side cover off thew left side of the rear end so you can have access to the rev. shift fork . As the linkage to it will come out with the range cover and it will fall over and when you try to go back together you will not bet the rod back in . If you have to go that deep into it then get a book and see what your getting into BEFORE you open it up.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
