As I posted over on the GT Forum, when those are used in starter mode, they get a shot of "juice" from the battery to the "A" terminal the SAME as if you were manually polarizing the unit.
So, if it cranks the engine, it's NOT in need of polarization... it's already been done.
Try (for a short period of time) full-fielding the unit be grounding the "F" terminal on the generator. If it charges that way, it points to a bad regulator or a regulator that's not grounded properly.
One thing to look for... The regulators are rubber-mounted and have a little braided copper lead jumpered around the rubber mounts to provide grounding and sometimes those jumpers get damaged/broken/torn off.
Are you bale to check the charging voltage at the generator's "A" terminal with the engine running above idle to see if grounding the "F" terminal makes it charge?
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
