Posted by The tractor vet on March 05, 2010 at 18:53:22 from (75.19.124.251):
In Reply to: 460 diesel smoke posted by dennisn715 on March 05, 2010 at 18:34:41:
You did not say what color smoke it was white , gray , black. You did not say how well it started . or how it ran when first started. How long are you holding the glow plugs on for ??? at this time of year you may have to preheat for up to two min. and also hold them on even after the engine has fired for a min. or more to build the heat . It could be that you have some injectors that are not cracking at the correct pressure and slobbering fuel in , you could have cracked pre cups and this will cause it to not fire correctly . You could have a couple bad glow pulgs. You may be low on compression due to wore out sleeves and rings. Could be that the valves are sunk to deep in the head and this will be just enough to throw them off and cause it to be low on compression and smoke till she is coming up on to run temp in the combustion chamber . If it comes down to a rebuild then take the time and do it wright buy doing a complete rebuild by the book and get everything set to spec.'s . When they are done wright they do run sweet . And oh that is good enough is not good enough , being a little excessive compulsive when doing a engine job is not a bad thing and makes for and excellent rebuild .
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
