If it has an alternator (or had one), its likely 12 volt and its likely Negative Ground. DO NOT wire ANY alternator at reverse polarity. Also if it has a Delco 10SI Alternator or any other, a DC genny type of Voltage Regulator WILL NOT BE USED. What you have would be easy to diagnose if we were there but tougher based on tid bits we get off the net
If it were mine Id start all over and take it back to original which is likely 6 volts and Positive ground. You can get a new complete wiring harness from Jim at Agri Services in New York www.wiringharnesses.com and Jim gave you a URL link to Bob M"s Wiring Diagrams
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
