Stuck in low, does this mean lever doesn't move, or mean lever moves and valve doesn't move, or lever and valve both move but still drives in low. These are some things you will need to determine. It may have blown the direct drive clutch causing low only and also the noise. I would say you should be able to determine if noise is limited to ta by shifting speed trans into a neutral position. There is actually no detented neutral but you can find it between gears so as only ta and counter shaft are turning when clutch is engaged and there fore the problem would be limited to that section of power train.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
