Re: Plate behind carb / manifold Farmall M
Posted by MisterT on March 09, 2010 at 11:51:00 from (209.152.78.140):
In Reply to: Plate behind carb / manifold Farmall M posted by Bob02 martin on March 09, 2010 at 11:29:51:
3500sport said: (quoted from post at 20:39:02 03/09/10) One of them is leaking coolant.
Should I just RTV over it? Or maybe JB weld?
Thanks for the quick response!
I also had condensation in my oil when I checked it (looked like chocolate milk and after letting it sit the water separated from the oil. I wonder If this could be the culprit?
The water header cover leaking coolant has nothing to do with condensation getting in the engine oil. You need to change the oil and the filter NOW, and then watch the oil for future contamination which could be the result of internal coolant leaks such as a cracked block, cracked head, or a bad head gasket.
Applying more RTV to an existing coolant leak will be only a temporary, band aid fix. To fix it right, you need to remove that cover, clean everything good, get a new gasket, and re-install. While you have the cover off, inspect it good. You may find it to be rusted away beyond use.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
